wolfe10
Jun 18, 2014Explorer
If you are willing to spend bucks on this, and your alternator has an external regulator (or could be wired that way) by far the best solution would be to fit a SMART REGULATOR. Similar to smart charger (120 VAC), in that it has different voltages for bulk, absorption and float. Inverting 12 VDC to 120 VAC and then back to 12 VDC has a lot of build-in efficiency losses and extra complexity.
Used this one on the sailboat 120 amp alternator-- did all the battery charging for months at a time: http://www.westmarine.com/high-output-alternators/balmar--ars-5-12-volt-regulator--7807969
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
