ajriding's avatar
ajriding
Explorer II
Oct 28, 2015
Identify plastic tank type
How do I identify why type plastic I have on my tank?
The color is gray, it is a little flexible (not unusual for plastic).
The female threaded fitting is cracked, so I need to replace it soon. Im not sure of the best way to proceed either.
  • Thanks, do you think there is a difference between the different polyethylenes? hard or soft?
    I will order some welding sticks for polyethylene.
  • It's probably polyethylene. Here's a list of some manufacturers:
    RONCO - one-piece linear polyethylene
    TODD — one-piece polyethylene. Marine tanks.
    TRIONIC — one-piece polyethylene.
    ICON TECHNOLGIES (Camping World) — ABS plastic
    Ameri-Kart — LDPE polyethylene and ABS.
    D&M Plastics — polyethylene
    INCA Plastics Molding — polymer resin
    All-Rite — polyethylene. Makes custom tanks for out-of-business RV companys.
    Dura-Cast - polyethylene, Linear Medium Density (LMDPE)
    Freeman Engineering - polyethylene
  • Might be some info here or similar websites--just Google Rv tanks.
    The potable water tanks were/are polystyrene (sp?)resin (white) that is quite flexible, while the older grey and black tanks were dark coloured ABS and much stiffer. It seems they now have a newer type grey and black tank from what these people say.
    http://www.plastic-mart.com/category/33/rv-water-tanks
    You can ask them your question about repairs or replacement I would think.
  • my new to me Lance camper had a leak in the drain nipple on the gray water tank. I bought a plastic welder from Harbor freight. I never did figure out what type of plastic it was, however if you look on line (you tube) you can easily find vids on plastic welding, and I used the "bridge" method with the plastic welder. It worked out pretty darn good, I backed that up with JB weld for wet. I have filled the tank and its been sitting wet for about a week now and no sign of any kind of moisture. My guess is time will tell if this was good long term fix or not.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
