rjniles
Apr 07, 2018Explorer
Identifying Circuit Breaker
2009 Passport 195RB
I wanted to label all the 12 Volt DC fuses in my converter as to function as the panel label is blank. I pulled all the fuses and made sure everything was off. I left the shore power and the battery connected.
Strangely all was dead except my power stabilizers. I disconnected shore power and the stabilizers still would run. I disconnected the battery and the stabs were dead. The stabs (front and rear) each have a self resetting 20 amp circuit breaker mounted on the frame rail above the stabs. I tried to see were the wiring went but it goes into the covered underbelly of the unit.
Does any one have a clue where the wiring feeding the self resetting circuit breakers is run? I would like to install a disconnect close to the battery to open the stab circuit.
