js6343js6343's avatar
js6343js6343
I'll never do that again
After 4 years of RVing, and just when I think I am getting the hang of it, another lesson is learned the hard way.
I am in the process of putting the TT away for the winter. So I am pulling the anode rod to drain the water heater. I disconnect the city water hose to releive pressure and proceed to unscrew the anode. Suddenly, the anode rod launches out of the WH under pressure and a sustained blast of water crashes into my face. If my sons had seen it, I would be the deserving recepient of a lifetime of ridicule. Lucky I did not have the water heater turned on. Or the embarrasment could have turned more serious.
So removing the city water hose DOES NOT releive pressure. You have to open the faucets inside the rig. But I guess all of you already knew that. I guess I did too. But it is so easy to forget even important steps on these rigs. This is one step I will not forget again. File under "stupid"
Having RV issues? Connect with others who have been in your shoes.24,284 PostsLatest Activity: Jul 17, 2025
