mena661
Apr 03, 2014Explorer
bigcitypopo wrote:Yep or you can just leave the original converter and 12v wiring in place and just remove the 120V going to it. It could be used as a backup if you needed it.
I could probably put the converter in the pass thru. then pop under and run a 3 wire to the rear converter, and just unplug the original battery lines?
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
