NinerBikes
Apr 03, 2014Explorer
bigcitypopo wrote:mena661 wrote:bigcitypopo wrote:Yep or you can just leave the original converter and 12v wiring in place and just remove the 120V going to it. It could be used as a backup if you needed it.
I could probably put the converter in the pass thru. then pop under and run a 3 wire to the rear converter, and just unplug the original battery lines?
So how do I run 120V to the new converter/charger.... just run another line..
Tie in to an existing 120V outlet with some 14 gauge 2 wire and ground Romex. Attach end run to another junction box, with a 15 amp electrical female plug in outlet, and a cover near the PD 9245.
I'm a general contractor, specialized in remodels and additions, residential property. Give me a holler if you need an installer.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
