- kathyday1851ExplorerIm positive its not a propane powered gen. and its not duel power either
- Are you sure it is gasoline powered and not propane fueled?
- kathyday1851ExplorerI'll post a pic in the morning to show you what I mean
- kathyday1851ExplorerIt comes off the generator at the carb
- kathyday1851ExplorerThe1 line is hooked up to the generator carb but I have another line that I don't know where it goes
- Dutch_12078Explorer IIIWhat is the attached end of the fuel line connected to?
- Dusty_RExplorerTo the carburetor?
enblethen wrote:
Page 33 for remote wiring
Should have only one line for a gasoline unit.
Correct. Where does that 2nd line attach too on the Genset? Can you post a Pic of that 2nd line? The Onan GASOLINE Fuel pump is a very small PSI pump and will shut down or idle when excess fuel is not needed. There should be NO 2nd line or return line. Doug- When you look at the Link supplied, remember, the Start and Stop is a GROUND (negative) circuit. The B+ (positive) wire is for the ON indicator light in the switch and also goes to any Hour meter.
- Page 33 for remote wiring
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
