dougrainer
Mar 23, 2015Nomad
talotto wrote:
Assuming you have a clear view of the southern sky, 5 minutes or so; and yes, it can be very noisy, especially inside the coach. If no clear view of the southern sky it will seek forever. I did have the set screw come loose on mine once where the antenna motor connects to the mast screw - since the antenna wasn't actually moving it went into perpetual seek mode. Tightening the antenna set screw fixed it.
If no signal found it will time out after 10 minutes or so. It would help if the OP stated what Year/Model Winegard he has. They have changed the operation parameters in the past 1 to 2 years. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
