Golden_HVAC
Jul 31, 2014Explorer
Probably a problem with the wire size from alternator to the TC batteries. I would recommend installing a #8 or larger wire from the alternator to the relay, then a 50 amp automatic reset circuit breaker, then to the connection at the camper. This also needs to be rated at 50 amps, then to the TC battery.
The alternator voltage should be about 0.5 volts higher than at the battery while charging. Once the battery is almost full, then the alternator senses the battery voltage, and drops it's output voltage to about 13.6 volts to avoid boiling out to much water from the truck engine batteries.
A relay like Grainger part #6C017 will carry all the amperage that you need, and has silver allow contacts, for almost 0 voltage drop across it.
Fred.
Fred.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
