NinerBikes
Aug 01, 2014Explorer
RJsfishin wrote:
Pray tell, what does the physical size of a battery have to do w/ getting a battery to full charge, other than time ? So a group 24 battery is the only size that is not a pita to charge ? My 2 27s sure seem to be doing good.
On edit,....just remembered I don't use a hydrometer, so what the hell would I know !
RJ, you are the exception to the rule... and you may not have followed Landyacht318's thread on his group 31's being problematic. You might want to give it a read, if you can find the time to go through all 20 pages or so, it's a historical benchmark in charging problematic group 31's, and Mexicowander makes some astute comments about battery design and accumulator designs, as well as size parameters. Some of the ratio's plate to battery acid capacity, are not right or properly balanced in this size and shape battery.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
