RJsfishin
Jul 21, 2015Explorer
What did the led meter read while plugged into shore power ?
If it did not go well above 12 volts, (like 13.6) then your converter may not be charging the batts.
What does it read while unplugged, and running the big engine ? It should
read well above 12v, like 13-14 volts same as plugged in.
You maybe should not hit the road till you get the whole rig sorted out
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
