MrWizard
Sep 29, 2014Moderator
Ozlander wrote:MrWizard wrote:
Good Stainless steel is not very magnetic
The few people I have seen using induction cook tops
Used cast iron, or other iron cookware
Induction only works with iron and steel,
Yeah, but he said SS cookware.
yes he did.. I took SS to mean Stainless Steel
I guess he could mean a Brand Name ?
apparently most stainless cookware (not all) is useable
some works better than others
Induction-compatible cookware contains ferromagnetic materials – in other words, it contains iron, or has a layer with magnetic properties. Cast iron, enamel cast iron and most types of stainless steel cookware are all induction compatible (But not all types – for instance, All-Clad's MC2 line, which is made of aluminum and stainless steel, is not induction compatible). /p>
Aluminum, copper or glass cookware will not work unless they have a layer on the bottom with magnetic properties.
To tell if a pot or pan is induction-compatible, hold a magnet to the bottom. If it clings, the cookware will work on an induction cooktop. Also, many manufacturers have started putting a n "induction compatible" symbol on the bottom of their cookware or they'll note compatibility on their packaging. The symbol often looks like a horizontal zig-zag or a coil.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
