Boon Docker wrote:
Thank you BFL for that great explanation. Never realized that they varied that much through the day.
Now you see the "bigger picture"..
For the record, I never said that MPPT isn't worth it, just cautioning folks who think there is going to be some astronomically massive increase over PWM all the time.
You get a small increase in charging with higher voltage panel and MPPT, in a nutshell once the panel has enough sun to get it above 17V the controller now can start charging quicker (small amounts of course) and same at end of day when the sun is setting. Basically extending the time a panel can extract enough energy to start charging and maintain some charging current.
For a beginner just getting their feet wet in solar, a simple solar setup with 12V panel and PWM controller can allow them to see if spending more on solar is worth it..
Not every case will make it worth it so why muddy the waters?
Folks camping in shade for example would have to consider something more portable and moving 250W 24V panels would be a real pain to do. But yet, moving smaller 100W 12V panels would be much easier to do.
Example, Renogy 270W 24V panel
HERE is 65"x40" (almost 5.5'x 4'!!!)and weights 42 lbs, you are basically wrestling a item the size and weight of a 4'x8' of a sheet 3/4" plywood!! Would be hard to store also..
A 100W 12V Renogy panel
HERE is a much smaller and manageable size at 42"x20" (4'x 1.6') and weights 14 lbs. A much more manageable size and weight. AND you can ALWAYS buy two and wire in series if you really want MPPT.. Not to mention always can add more panels as you grow the system.
Large 24V panels may or may not fit on the RV roof top, not all RVs have 6'x4' open areas that would be needed for large 24V panels and yet may be able to fit more 100W 12V panels instead.
Sort of like a huge game of "Tetris"..
A 12V panel with MPPT most likely will not net very much additional charging efficiency, 24V or higher panel voltage is recommended if you really want to take advantage of MPPT.
12V panel systems can be upgraded, add more panels down the road, rewire the panels in series and add MPPT and get the best of both worlds.
