pianotuna wrote:
The 250 panel may be 24 volts--so you would have to move to a 24 battery bank.
This is where I'm getting a bit confused about solar panels and controllers...
The 250w panels in question have the following:
Max power voltage (VMP): 30.3 V
But doesn't the CHARGE CONTROLLER take care of converting the input voltage (and current) to be used to charge your 12v lead acid batteries at the proper voltage and current??? (provided the maximum input voltage isn't greater than that allowed by the charge controller).
Looks like the charge controller I referenced above has the following:
Max input power and voltage: 390W /12V; 780W/24V
But I'm not sure what the maximum panel voltage is.
But it looks like this one would, right?
https://www.amazon.com/Flexzion-Controller-Multi-Function-Adjustable-Regulator/dp/B08BP8P2MP/ref=sr_1_9?dchild=1&keywords=solar+charge+controller&qid=1607213851&refinements=p_36%3A-4000&rnid=2661611011&s=lawn-garden&sr=1-9
It mentions: Max. PV Voltage: 50V Is that max from the solar panel???
-Chris
