BillyBob_Jim
May 14, 2019Explorer
So other than some wood blocks in strategic areas, an in house frame, and an extra layer of 1/8" Luan in the sidewalls, they're built from the exact same **** you get from Indiana. Laminated walls pinch rolled and not vac bonded, vinyl wrapped luan faced MDF cabinet frames, Wall framing on wide spacings, so what if they weld both sides of the tube, plenty of others do also. 060 tube is noting special, standard 16 gauge. A lot of hot air IMO but the guy's in the vid are good talkers.
Then they're delivered to the dealer by a contracted transporting company using subcontractors who bebop down the highway at 85mph and care about as much as Joe Blow.
Just no Amish running around like chickens with their heads cut off so maybe a little more care taken in the assembly but not much. RV marketing is the greatest.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
