EV2
Nov 11, 2015Explorer
Never used one of these but i am assuming that they would measure the temps somewhat accurately inside the fridge? If so i will order one immediately !!!!
Thanks a bunch for the info and link.
Upon further review it appears the fridge temps have to be measured with the door open. Sigh, if it sounds to be good to be true....,
Go ahead, it will work great. You are not getting the temp of the air, you read the surface temp that is indicated by the laser pointer. So, you can read the temp with the door open. You can check the temp at the top and compare to the bottom and sides. You can read the inside of the door or even an item in the refrigerator shelf.
It is very accurate and works super.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
