Sam_Spade
Jun 13, 2017Explorer
Cobra21 wrote:
I don't think it would let much water in.
Brian
No but it will let some gas OUT.
That is why none come equipped that way to begin with.
That is also why you can't find a replacement cap with a two-way vent.
IF....you are going to do that, you need to modify your habits just a bit; NOT fill the can completely full, as that will guarantee gas will spit out your new vent hole. Even if not completely full a little gas will likely splash out as the fuel and can gets warmer.
THIS can be a serious problem if any occupants of the boat smokes OR the can is used in an enclosed space where the gas fumes can accumulate......and explode from a static spark.
The cans are made the way they ARE for good reasons.
If you are going to defeat that safety device, you need to consider ALL of the factors.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
