tommygun714
Mar 16, 2018Explorer
BFL13 wrote:
The OP is on the right track, but does not need to do anything with his OEM converter. Just use the new deck mount converter as a portable charger powered from the generator as required off grid for a fast recharge "50-90"
Make sure the gen has enough VA to run the charger. A 2000w inverter gen is about maxed out with about a 70a non-PF corrected charger. The PD 80 amper is non-PF corrected. Some say they have run an 80 amp PD with a Honda 2000. I don't know how!
I have a 3000w Honda to run my PF corrected 100 amper. I doubt a 2000w could run it at all.
Use the OEM converter when plugged in on shore power, same as always.
There are other choices besides a PD, but whatever floats your boat. I use an adjustable PowerMax on the batts in the front of the 5er when off grid.
Now I feel I am getting close...Thanks
So if I leave OEM Charger / Converter in place and on shore power...don't I need to disconnect the wires from the old single battery that I am replacing with the new bank of 4 6v batts? And that same bank has the new (Progressive Dynamics (PD9270V) 70 Amp Power Converter with Charge Wizard) attached to them also? Just wondering if there is a voltage feedback, or other issues having both connected? We are doing many weeks of Boondocking and dry camping this spring and summer - and forever, so we want to be able to get the batts charge up, when needed, quick.
I have a 3500 peak, 3100 running Champion Duel Fuel Gen. So that should get us up and going, AC too if needed.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 12, 2026
