valhalla360
Apr 30, 2021Navigator
What are you putting the tile into?
- A heavily built diesel pusher with 3/4 plywood floor and plenty of stiff joists, it may be viable.
- A lightly built low end travel trailer with the foam plywood sandwich floor, expect a lot of cracked tiles in a short time period.
Also, you need to consider the operation of the slides. Many are designed to use the carpet as a surface to slide on...hence why the industry moved away from vinyl flooring.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
