Bobbo
Dec 01, 2015Explorer III
BFL13 wrote:Bobbo wrote:BFL13 wrote:
(As it stands now for what is available, if I could not have an adjustable voltage converter like my adjustable PowerMax, I would choose the PD and Charge Wizard, being sure to get the next size larger and mount it right next to the batteries with short fat wire. I would count on the solar later in the day to get the batteries to 14.8 whenever possible if that is what their spec requires.)
I think this quote from BFL13 says it all. He has his preference, as do we all. However, he is giving kudos to PD in that if his particular pet was not available, the PD is the best choice out there.
He is also saying, indirectly, that anyone who does not want to fool with the time/effort to set up the individual charging profile, the PD is the best out there.
The only part of his quote that I was not able to do when I re-did mine was to move the converter right next to the batteries. It is still about 12 to 15 feet away, but I did go with fat (4g) wire, and upgraded from a 45 amp to the 55 amp.
Exactly right, except I don't see much difference in effort in having to push buttons on the Charge Wizard to get what I want, from twiddling the knob on my adjustable :)
The difference, to me, is that I have never had to push the button. The PD automagically did what was needed. I did push the button once to see if it worked. It did. I haven't touched it again.
Also, and more importantly, I don't have the expertise or equipment to set the dial exactly where it needs to be. Nor do I want to manually monitor it to make changes. I trust the PD engineers more than my uneducated self.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
