dodgeramman123's avatar
Aug 01, 2014
Installing a 120V-30amps outlet
I want to install a 120v-30amp RV receptacle on the outside wall of my vinyl covered garage. I've read on how to wire it, and understand that well. I would like to know what kind of weather proof box should I use for it? I want it looking decent. Thanks in advance!!!
  • dodgeramman123 wrote:
    I want to place it on the front of the garage, so I would like it to look like the one I installed their now, which is a 120V GFCI receptacle. I think I could use a regular outlet box, but was wondering what to use for a cover to protect it from the elements. Here is a pic of what I mean. I haven't been able to find one with the hole in it to fit the 120V-30amp outlet. Any suggestions will be appreciated.
    http://www.filefactory.com/file/58fdpkp9rerx/New%2015amp%20receptacle.jpg
    Finding an in-use cover for a 30amp plug may be rather hard. Check with an electric supply(wholesale) place. Better info than a big box store.
  • I saw that you read "how to do it" but here's a tip. Check voltages at the main breaker box from line 1 to neutral then line 2 to neutral. Select the line with the greater voltage. In a straight line, if the distance from the breaker to your outlet (receptacle) is greater than 40' I would consider using only 8AWG wire, absolutely nothing smaller (meaning no higher number gauge wire).
    With breaker OFF, smear dialectric silicone grease on outlet terminals if you live where humidity gets 60& or higher.
  • I want to place it on the front of the garage, so I would like it to look like the one I installed their now, which is a 120V GFCI receptacle. I think I could use a regular outlet box, but was wondering what to use for a cover to protect it from the elements. Here is a pic of what I mean. I haven't been able to find one with the hole in it to fit the 120V-30amp outlet. Any suggestions will be appreciated.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I just got an outlet box at my RV dealer.. Looked good.
    The Home Depot link above is an exact match for it.. I like the fact that the door opens UP and thus has a natural tendency to close.
    Fed it with a 20 amp breaker though due to the size wire that was already there.
  • I don't think I'll be getting a bigger trailer anytime soon, but who knows? Right? If I did I know how to wire for it also. Maybe I'll win a lottery!!!!! Yeah!! Right!! I was just looking for that type of waterproof box, which also looks good. Thanks for posting it for me.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
