Bigdog's avatar
Bigdog
installing a cutoff switch
I just had to replace the 12V distribution panel on my '01 Tradewinds DP and now have discovered that I have a major battery drain which seems to be before the cutoff switch and really don't want to get the mobile tech out again. I am thinking about getting a regular marine cutoff switch and installing that to totally cut off the power. I am not worried about the alarm as I already had to disconnect that. There are two ways to connect these, one is to cut the cable and install connectors on each of the cut ends and the other is to get a post connector and not have to worry about cutting that big piece of copper cable and pressing new ends on it.
So I'm looking for advice on this from folks that have done this.
  • find the problem. start by puting a meter on the battery, then pull fuses one by one, till the meter drops.
  • You have a power draw somewhere and need to find it. Could be a dangerous situation.
  • I would be trying to trace the drain and fix the problem.
    Marine disconnect should work very well.
  • Seon's avatar
    Seon
    Explorer II
    I too put a cutoff switch to disconnect the batteries when the RV is stored in the barn.
  • Here's my shunt and battery disconnect switch. Disconnecting alarms while using the RV would be unwise.
