Trackrig
Aug 06, 2018Explorer II
McKenziek wrote:dougrainer wrote:
The problem is not the door specs. The problem is, the door is a front door on a Diesel and curved at the top half. You will have to remove the drivers and Pass seat to SAFELY swap them out and prevent damage to the seats. You also have the DASH to worry about. It is best to pull a side LR window. That is what I do. You will also have to disassemble the old refer and the new refer to get the cabinet out and in. We also do that. Disassemble just means removing the 4 doors and hinge brackets. Makes the refer lighter and now will go thru the window cut out. Going out the entry door or window cavity cutout will still require disassembly of the doors and door hinge brackets and the optical board. Doug
Without actually being there to measure, i'm guessing my side windows are maybe only 16-18" tall but I could be wrong.
On our 2005 Excursion 39s, here's the side window. I can't measure it at the moment, but it must be at least 40" x 40"
Here's the driver's side window, must be around 30" x 40" or larger.
Bill
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
