tenbear
Aug 01, 2013Explorer
When I went from a Magnetek 7345 to a PD9260 I increased the wire size from #8 to #4, partly to lessen the voltage drop but also because the new converter is capable of 60A charging current.
With your battery bank you could be seeing 80A charging current and #6 wire will have a substantial voltage drop, depending on the length of the wire. I would increase the wire to #4, or more. I don't recommend parallel #6 wires since if one comes loose or breaks all the current flows thru one wire which may be overloaded.
As an aside, it is not recommended to have batteries of different types in parallel.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
