BFL13
Aug 02, 2013Explorer II
McKenziek wrote:
I like the idea of keeping the old converter hooked up and installing the 9280 close to the 6V pairs. Is there any reason why both cant be used to charge at the same time? How would you wire this?
Roy shows a wiring diagram above. You can invent your own to suit. You can run both to charge the batteries. Limitation will be your generator rating. My Honda 3000 can run up to 130a worth of ( non-PF corrected )chargers before it pops its breaker.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
