jedavisss8's avatar
jedavisss8
Installing an oven into a former rental rv
Hi All,
I am considering a former rental RV. I have found that the El Monte RV models are out of my price range. The Cruise America models will work. However, none of them have an oven. I am guessing the space for the microwave is too small to install a convection oven.
So, here's the question: have any of you installed a regular oven in the space below the cooktop. No oven is nearly a deal breaker for me.
Thanks for your responses.
  • We cook inside almost exclusively. Still, I would never own an RV with an over, it's just not necessary in most cases. Our convection/microwave does all the cooking we need. However, it is only the 2 of us. If more come along on your travels, an oven might make sense.
  • I think most of us cook outside. Even in the rain, I cook under the awning.
    To me, an oven would not be a deal breaker. Several options already shared. We've used the oven once in nearly five years. Twice actually if you count testing in PDI.
    Mike
  • Unless the microwave wave is a special RV unit (smaller than usual) a convection/microwave should fit right in.
  • JoeH's avatar
    JoeH
    Explorer III
    Might want to consider a countertop convection/air fryer/over combo. Then you can take it outside when weather is appropriate to avoid heat and odors in the
    RV. FWIW, I pretty much never cook inside. I have a grill, griddle, air fryer, slow cooker and other gadgets in one of my bays that I can setup outside.
  • If you are considering installing a regular oven in your Cruise America RV, I recommend that you take the measurements of the space below the cooktop and bring them with you to a local appliance store. The staff at the appliance store will be able to help you find an oven that is the right size for your RV.
  • ...might get more help in the appropriate (sub) forum. Just sayin'... ;)
Having RV issues? Connect with others who have been in your shoes.24,195 PostsLatest Activity: Feb 05, 2025
