time2roll
May 18, 2015Nomad
The GP3000 can power those items full time or you can install a 30 amp transfer switch. Pop a 30 amp breaker into you main panel to feed one side of the transfer switch. Inverter feeds the other side of the switch. Transfer switch will choose one of the two and feed power to the 30a subpanel.
PD5100 switch 30a $83
Yes you will move the branch circuits you want to run on inverter power..... off the main panel and onto the subpanel.
Yes you should have six+ batteries to properly drive 3000 watts of inverter.
> Forum Members Solar Installations With Pics
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
