time2roll
Mar 26, 2020Nomad
You have new wire for the inverter sized 1/0 minimum correct? I recommend 200 amp fuse if the wire is longer than a few feet or passes through anything.
As said... leave all the OEM wire and connections in place. Just connect the inverter 12v terminals direct to the battery with the new wire. The wire to the jack is not removed or spliced.
