time2roll
Mar 26, 2020Nomad
letup27 wrote:Yes although if you have access I would pull an entire new section of wire and avoid the Jbox.
Since I'm disconnecting the shore line from the 30 amp breaker in the panel box that romex #10 wire has to run to the inverter. Since its not long enough I will have to add a junction box and extend the wire to the input of the inverter. The output of the inverter will run to the 30 amp breaker. Is that correct?
