cavie
Mar 26, 2020Explorer
letup27 wrote:
Since I'm disconnecting the shore line from the 30 amp breaker in the panel box that romex #10 wire has to run to the inverter. Since its not long enough I will have to add a junction box and extend the wire to the input of the inverter. The output of the inverter will run to the 30 amp breaker. Is that correct?
So if I understand this right the existing converter is use to convert a/c to d/c when Im plug into shore power. If its not being used the d/c power will be supplied through the wire I will leave connected to the battery.
If Im correct with all that then my last question would be since I disconnected the existing converter then how will the batteries recharge?
You can not power the whole RV of the inverter. You will need to install a small Sub panel and select just a few circuits to be inverted. You need to call an electrician. This is not a DIY over the internet project.
