BFL13
Mar 27, 2020Explorer II
Some Rvs have the converter on the same breaker as some outlets, so you can't just turn off the breaker to shut off the converter if you need those outlets to be live from inverter.
In that case you need to insert a switch on the converter's pos wire before it gets to the breaker, or else re-arrange the breakers.
Easiest if the converter plugs into an outlet. Just unplug it.
