wa8yxm
Mar 27, 2020Explorer III
time2roll wrote:
Are you doing a sub panel?
I thought you were doing whole house like this:
VERY GOOD Diagram.. The only differences between how My RV is wired and the diagram are primary cosmetic. But I will list them
The shore/generator transfer switch is automatic (the photo suggests a manual) the isolator is a different type... None of this matters to the original poster.
Oh and I kept my original Converter on line since I like it better than the programmable inverter/charger.. It is hooked to the MAIN box so it does not make a circle off the inverter.
I was going to remind the OP to set it up with a sub panel You did a much better job.. Thanks'
