BFL13
Mar 29, 2020Explorer II
letup27 wrote:
Thats correct, but I'm talking about the 12v side. If your looking at my diagram where I wrote positive, that wire runs from battery Positive to Jack/disconnect/brake before running to the 12v board.
Im not sure what your referring too..
In that case you need to insert a switch on the converter's pos wire before it gets to the breaker, or else re-arrange the breakers.
Breakers for air conditioning/water heater and convert will be off when on battery power. In the future I could always add a sub panel with a switch.
The transfer switches are for 120v so you can't get 240v and fry your appliances. I have a manual switch (me) that plugs the shore power cable into the inverter. I pull that out and plug it into the portable gen or to a pedestal as required. Automatic transfer switches are mostly for when you have a built in generator, but also can be used as others here are recommending.
Check your AC breaker panel. If the breaker marked CONV has just one black wire going into the bottom, then it can be used the switch for the converter. If it has two black wires going into the bottom, you need to find what circuit that second black wire is on. It might be for outlets you want to stay live when on inverter.
BTW don't trust the OEM markings on the breaker panel. Check each one by turning it off to see if it is really for what it says. Same with the 12v fuses. ( "Hard to get good help these days")
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
