3_tons
Mar 29, 2020Explorer III
letup27 wrote:
I was removing the existing converter. Why would I need it if the Aims inverter is a charger and has a ATS. Seems like Im getting conflicting information. Take a look at my diagram and tell me what you see wrong . Line by line
thanks
No need to go down a rabbit hole of removing-disconnecting-altering-modifying, etc, etc your existing converter, unless you’re wishing for unnecessary work and added grief...Those ‘elsewhere‘ who told you such should be disregarded - the info provided here seems adequate....Low frequency versus high frequency is not in any way relevant to your *otherwise straight forward (no sub-panel) install...
* per your previously stated objective
1) Shore Power to inverter (Shore power disconnected from Main Panel)...
2) Inverter to Main Panel (where shore power previously was).
3) Battery to inverter - New properly sized cables to inverter, fused in NEW positive cable.
DONE
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
