Ivylog
May 09, 2013Explorer III
OnaQuest wrote:Ivylog wrote:
Because they say not to and so the water will drain out. Turn the unit around so the front is facing to the rear. Unlike with a MH you will not be running it going down the road so air flow while moving will not be a problem.
....and let the wind resistance rip the shroud right off.
Guess you've never seen a rubber roof bubbled up at the front from the low pressure area created by the air off the front of the rig.
If Doug Rainer says it's OK sloped down... go for it.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
