SJ-Chris
Jun 13, 2018Explorer II
Installing/swapping Coleman Mach thermostat in my RV
I've got a 2008 Four Winds Chateau 31P Class C RV. I think my thermostat is faulty. Sometimes the AC turns on, sometimes it doesn't. I've got another similar RV and when I slide the temperature control knob back and forth I can hear a "click" noise when it crosses over the current temperature (...turns the AC on/off when it gets to the right temperature....same for when the furnace is running). On this (presumably) faulty Coleman Mach thermostat in my 2008 RV I do not hear such a click.
Does anyone out there have a Coleman Mach thermostat...can you tell me is you hear a "click" as you slide the temperature knob back and forth? For example...let's assume it is 80 degrees inside the RV. If you turn on the AC but the thermostat temperature slide is on 90 degrees your AC should not turn on. BUT, as you slide the control down past and below 80 degrees do you hear a "click" on the thermostat and then your AC turns on?
I'm assuming (hoping really) that it is just a faulty thermostat. I have ordered the exact same Coleman Mach to replace it. There are 6 wires coming out of the wall and connecting to the thermostat. I assume replacing it is as easy as matching up the wiring and connecting the new thermostat. This is 12v tiny gauge wiring. I'm very familiar with splicing/connecting regular 120v wiring with wire nuts/etc. But these wires are tiny and look delicate. What do you recommend for splicing these wires together to connect the new thermostat? Is there a special crimping device? Do you use tiny wire nuts? Any suggestions?
Thanks in advance for you help!!
-Chris
-Chris
