DryCamper11
Nov 19, 2013Explorer
truepath wrote:
Does the fact that two batteries are charging at the same time work or does it confuse the Wizard? Also, does the fact that the 1315 itself uses some of the available charging voltage degrade or effect the charging? Thanks for any help in clarifying this issue.
The Wizard does nothing more than change the charge voltage based on a time schedule. It doesn't care if there are two batteries or more. The 1315 seems to use a relay (which I think is optimal due to the zero voltage drop) and the small current it draws will have no more effect than the small current your refrigerator or other 12V draw would have.
So, as others have posted, it will work fine, and I think you made a great selection of components.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
