Naio's avatar
Naio
Explorer II
Jun 28, 2015
Series/parallel charging question for les tinkerers grandes
I have 2, 12v AGM batteries that I use in series to run a 24v motor. The system has a solenoid controlled by an on/off switch that interrupts the power from batteries to motor.
When not in use, the switch is off. Am I correct in thinking that the batteries are not considered to be connected in series at that time?
Except: There is a 24v charging port on the system, which connects to the batteries via tiny (18ga?) wires. THAT is the only thing completing the circuit.
I usually use a 24v charger, but sometimes use a 12v (connect to one battery, then to the other, till full or for a set period of time).
I was thinking that I could use a solar or alternator-charging setup the same way I use the 12v charger. But then pianotuna said some stuff I do not fully understand:
The charging of one 12 volt battery followed by the other one may cause them to become out of balance which would require more frequent equalization...Balance is a whole bunch more important that most folks realize for longevity of a battery bank.
I understand that one battery might be at, say, 12.9 and the other at 12.97. Is that what is meant by balance? Frankly, this happens all the time with the 24v charger - maybe because my batteries are old? They still perform very well.
And what does this have to do with equalization?
Then smkettner said I should get a switch to switch them from series to parallel.
But I had not mentioned the solenoid to these/you guys. I only thought about it later. Does the solenoid make the whole issue moot, or do I still need to think about a switch and balancing?
