mikathi's avatar
mikathi
Intellipower Convert Question.
Is the converter a stand alone unit that will run once it is plugged in or does it have to have a transfer switch to operate? My 12 volt house batteries have not been charging and I've narrowed it down to a faulty transfer switch (to the best of my limited knowledge). When I manually pushed down the switch in the transfer box (white wire leads) the converter came on and ran for a few hours then the switch would release and the converter would go off. I ordered a new transfer switch and decided to take the old switch out and connect the shore line and load panel lines together (L1 in to L1 out, L2 in to L2 out, Neutral to neutral, ground to ground, leaving the generator lines taped and to the side for now) thinking that the converter would then run and charge the house batteries. But the converter did not come on. So again, the question is, is the converter a stand alone unit that will run plugged in the 120V and run. Thank you. Just trying to expand me knowledge of the RV 12V system and how it works. Any additional input would be appreciated.
  • Yes, the converter will put out "12v" when it is getting "120v" in. You could use an extension cord by-pass to plug the converter into (if it is a plug in type) and get the batteries charged up while you solve the transfer switch problem.
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 09, 2025
