dougrainer
Mar 08, 2019Nomad
99 PERCENT of the time when an Intellitec does NOT show 50 amp, it is because you do NOT have TRUE 50 amp service. True 50 amp service will have 240 volts between the 2 hot leads. If you do not have 240 volts you do not have correct 50 amp service. If you do have 240 volts between the 2 hot leads, download the manual below. Doug
http://techsupport.pdxrvwholesale.com/wp-content/uploads/2019/02/Intellitec-Smart-Energy-Management-System-00-0068X-X00-53-00683-300.pdf
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
