rjsurfer's avatar
rjsurfer
Interesting dual MPPT issue
I had a 400 watt system with the Renogy 40 amp MPPT Tracer controller for awhile now and its working great. A few months ago I purchased a spare controller (same) for backup but decided I might as well get a few more panels (2-150 watt) and have a complete running backup system.
No problem with install ran duplicate serial connections same gauge, distance etc. Both controllers located next to each other same battery connections.
The interesting thing is that when load drops and the controllers output drops below 3 or so one controller output will drop to zero while the other continues to charge at 3-4 amps. Sometimes it's one controller sometimes it's the other.
As soon as I put a load on the batteries like fridge or water heater the "dead" controller comes back to life and they both work fine. Obviously they don't output exactly the same current due to different panel locations and panel sizes.
Called Renogy tech support not much help, of course they say its normal!
Both controllers have identical internal settings.
I've reset both systems from scratch and restarted, no difference.
Controllers monitors read almost identical voltage outputs although there might be a tenth of a volt difference sometimes.
And when batteries are completely topped off at lets say 14.8 or so they both will go to zero.
I'm not too concerned or should I be?
Ron W.
  • OP back,
    Thanks for the explanations, I think I understand:-D
    I'm taking Renogy's take on it and going with that.
    Off on a 6 week cross country in a few days, looking forward to monitoring the monitors! Better than TV and eyeballing the tank level lights.
    Ron W.
  • OP back,
    Ron W.
  • I would NOT worry about...it
    Variances in the internal components and component temp
    Probably account for the fact that it can be either controller that shuts down
  • I've run up to three of the Eco-w's on one bank and it happens there too even with identical set ups and settings.
  • Two chargers on the same battery will have slightly different charger voltages. So the "spread" between the charger and battery is greater with one than the other. When the battery voltage rises to be the same as the lower charger voltage, no more current from that one while the other brings the battery voltage up to its so there is no more spread there either.
    When the battery voltage is lower (more load or less of a state of charge) so there is spread between both, the current from the smaller spread will be less than from the larger spread in proportion to the size of the spreads. Only if the two spreads were exactly equal will both currents be the same amps.
    Even if the two controllers were identical in voltage their wirings to the battery will have slightly different voltage drops.
    But that's not all.
    Output current with MPPT controllers (have a buck converter) come from the watts at each controller's output, divided by battery voltage. Output watts is input watts less controller efficiency. Input watts is array watts less line loss between array and controller. Even if the arrays were the same, the watts would be a little different. But as you noted, you have two different wattage arrays, so you will have different output watts and so different output currents.
    However that still leaves the situation where charger current can be different but with identical voltage spreads, one would not drop out first.
    The mystery would be why is it not always the same controller that "drops out" first? Perhaps at times the 400w array is shaded or at a different sun angle (slight opposite roof tilt each side of the RV?) so it has fewer watts than the 300w array?
    At very low battery acceptance rate (battery near full or full and overcharging) the thing could tip either way where at times the 400w array has less output than the 300 but also has the higher voltage drop to the battery?
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
