pianotuna
Oct 01, 2020Nomad III
If we assume it is the size of a barrel of oil, then the swept area would be limited to that dimension.
I believe jet engines use a constriction to increase the speed of the air, before mixing it with fuel and igniting it.
The constriction might allow a lower start up wind speed, but the opposite side of the coin is a reduction in swept area.
For example, an oil-barrel sized Savonius rotor with h=1 m and r=0.5 m under a wind of v=10 m/s, will generate a maximum power of 180 W and an angular speed of 20 rad/s (190 revolutions per minute). (from Wikepedia)
That's a wind speed of 20 mph.
I can't imagine having an oil barrel on the roof at highway speeds.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
