John___Angela's avatar
Oct 15, 2013
Interesting results of power use audit when dry camping.
So we have been dry camping for about a week in fairly lousy and cold weather (read below freezing every night. So as we have to be here for a few more days I decided to see what sucks the most power on a daily basis in these kind of conditions. eg stuck inside most of the day, TV on all day, Computer on all day and of course 2 X furnace loads, cell charging, residential fridge, microwave, toaster, beverage water heater, lights (mostly LED) etc etc. (Man we are power hogs) Using the Samlex remote watt usage meter and a clamp on ammeter I figured out the following.
Surprizing the biggest sucker upper of power is the 32 inch Vizio TV. Draws between 90 and 105 watts and its on of course all day. Next is the computer I am typing on, (ASUS all in one with about 20 inch screen). It is a close second at around 70-80 watts and of course its on all day as well. Third was the residential 22 cubic foot fridge which also draws around 100 watts but is on about 20 minutes per hour (but all day and night of course). After that the cooking appliances etc draw big current but for a short time so after a little calculation I'll put the two furnaces next. After that its all little stuff.
Anyway, today we have sun so the solar system is cracking out 25 -30 amps so genny run time is minimal. (Hour in the morning at breakfast and the same at supper}. Other wise it has been more than double that run time on the cloudy (and colder) days.
And this is what you do when you are bored and waiting to go south. :) (as soon as we get a couple of minor business things sorted out)
  • Thanks for posting your findings. There is little reference to real world numbers of boondocking setups, especially broken down into use by devices used.FWIW, my Magnavox 32" LED backlit screen draws 33 watts in Standard mode.
  • I was surprised at how much our 15 inch LCD/DVD combo used this last trip. I converted it to 12v and was running it with a 35ah gel cell. I ended up needing to charge that everyday. That battery usually runs a portable DVD player or radio and charges phones a whole trip.
  • Ivylog's avatar
    Ivylog
    Explorer III
    X2 on getting a LED TV. Should have tested how much of a hog the 32" plasma was before replacing... not to mention the heat it put out.
    Now if I could get my Freedom 2000 to put out more than 100 amps charging into my AGM batteries I could decrease my genny time to less than 3 hours per day.
  • This will be a popular thread... I know I need to find ways to conserve watts.
    What about a laptop instead of a desktop?
  • Get rid of that CCFL LCD TV and get a LED/LCD TV or a OLED TV you will save 70% in power consumption.
    Please do not toss it in the trash
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
