Dakota98
Jun 25, 2015Explorer
mchero wrote:Dakota98 wrote:
My drain line ran down & underneath the trailer. If you are running the drain line outside of the vent, as indicated, why can't you still use the line for the 12 volt connection ? Run the 12 volt through a small hole in the drain tubing further up from the opening & silicone the area of exit.
PS, My tubing had a splice in it just before it went down through the base of the frig area & underneath. I undid the splice, ran the wire out & then reconnected it. You could add a slice to yours & make it easier to get the wire through.
Just ran the positive (Red) down the grey tube. Did not need to run a 2nd wire because fan grounds to fins via the clamps that secure it. Very impressed with the quality/build of this guy!
I think you & I have the exact same fan, got mine on Ebay last Spring. It works great. :B
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
