Profcadd's avatar
Profcadd
Interior DC Fuse Location
Help me out someone. I am pulling my hair out. A few of my interior lights quit, probably on same circuit. For the life of me I can't find the 12 volt fuse box location for interior lights etc.
On the dash there is a removable panel with many fuses. None of these are for interior circuits. I contacted Newmar 2 days ago, and they have not replied.
I hope someone has the same coach?
Newmar Mountain Aire 38' Vortec 8.1 on Workhorse chassis.
Thanks....
  • Thank you all for your valued input. Yes indeed the 12V distribution panel was up above the 120V AC panel was hidden behind a drawer in the bedroom. Removing the drawer exposed the hidden gem.
    Thanks again.....
  • Newmar installs the 12 volt fuse panel next to the 120 main breaker panel. So, if you know where the 120 breakers are, the 12 volt will be close by. On "some" model Newmars (very few) they installed the 12 volt panel in the bath in one of the overhead cabinets. Doug
  • Find the "house" power centre with the 120v breaker panel and the 12v fuse panel and likely the converter with that unless you have an inverter/charger. Sometimes found under the fridge
  • Look at the 120 volt AC distribution panel. Many on the side is a small metal plate held on by a thumb screw. behind this plate is the 12 volt DC distribution fuse panel.
