I'm having an issue with myinside lights. They ramdomly go from dim to bright. I have a WFCO 55 amp charger, that goes from 14.3 to 13.2, on a 1 minute cycle. I'm on 50 amp shore power at a campground...
Sounds like your WFCO is going flaky. I suggest a 35-45 amp Progressive Dynamics. Smaller than what you have but you don't need 55+ for 2 batteries and seldom boondocking. WFCO has probably seriously degraded your batteries. The may recover somewhat but would need some TLC to do so. (check water levels, apply a good charge, check SG and then equalize at near 16 volts while monitoring closely). Do not get another WFCO! Any RV dealer should have PD's in stock.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
