I'm having an issue with myinside lights. They ramdomly go from dim to bright. I have a WFCO 55 amp charger, that goes from 14.3 to 13.2, on a 1 minute cycle. I'm on 50 amp shore power at a campground...
You're batteries WERE NOT GETTING CHARGED, that is the reason they are only fair cond. Deep six the WFCO, get a PD9245, let the batteries get a good charge, then see if they're still good enuff for your camping style. Be sure to get the wizard Pendant w/ the converter (sometimes optional) so you will have 3-4 stage charging at 14.4 volts
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
