My interior lights work on shore powerbut not with battery. Battery is charged, and brake away switch has juice, all fuses good. Any ideas would be appreciated...Thankyou
Did you connect the battery with the correct polarity? If not, then probably blown reverse polarity fuses.
You probably have an auto reset circuit breaker (a little metal box with two terminals) in the wire between the battery and your converter. With shore power off, check to see if you have 12 vdc on both terminals. If not, bad breaker.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
