rexmitchell's avatar
rexmitchell
Intermittent 12v electrical issue
Running the camper on generator power this weekend and cut the generator off to find I had no 12v power anywhere in the camper. Checked all fuses and pulled the fuse panel with zero 12v power coming in. Went outside and battery tested fine, replaced the 30 amp blade fuse just for fun and it tested fine. Got to the junction box and had power there as well. Finally gave up after an hour of taking things apart and figured I’d bring the camper home to mess with it more. Fired the generator up again for some coffee, then cut it off and what do you know…..12v power everywhere. Well problem solved I guess….no. Turn off the generator and go to unhook the battery since I won’t be out for a couple weeks. Just for fun hooked it back up. Nothing again. Shook the wires and it came on. Did it again and lights are back on. My first thought was the connectors but that doesn’t make sense from the original problem where I had power 4 feet away at the junction. Any ideas on what to check or replace?
One other thing I forgot to mention. I don’t recall the green light on my fuse board ever being on this weekend. Not sure if that is related but worth mentioning.
  • You have a failing connection out by the batteries. There's just no if's ands or buts about it. The key now is figuring out where the trouble point is. Start by carefully examining the entire length of the wires from the battery up until they enter the trailer. You might find an abraded part or see a lot of swelling under the wire insulation jacket.
    Start trying to isolate smaller sections of the wires between the battery and the trailer. Like grab the wires about 10 inches before they go into the trailer and hold you hand still. Then use your other hand to wiggle that last 10 inches of wire and see if anything happens. Make sure you wiggle, push, pull and bend the wires to look for failures. Then move back further along the wires and try again. My guess is there is a small circuit breaker mounted on the wires and sitting under the tongue. If you try to wiggle the wires at the circuit breaker the posts will move slightly and the power will go in and out.
  • Thanks, if the power hadn’t been good at the junction originally I’d have said it was the connectors. Just seems weird or that it may have been another problem as well. Going to replace the connectors next week anyway, they look original and that would make them 11 years old. Hopefully that is it.
    This is a clear indication of an intermittent connection problem. Most likely source is the battery post connection or the wires. Flooded batteries if that is what you have vent corrosive fumes so check everything. Even shrink wrapped battery wire can/do fail between the wire and connector.
    One cheap and clear way to isolate is to completed clean the battery posts and replace the connecting cables. Or using long leads between the post (not the connector) and the far wire end and check for a connection with a voltmeter. Better yet buy a DC clamp on ammeter, leave lights on and check for current to isolate to a wire.
    Intermittents can be hard to isolate.
