YC_1
Dec 18, 2014Nomad
Turn the gas off and then remove the small orifice on the end of the propane tube that supplies the gas to the burner. Soak it in alcohol. DO NOT USE anything else such as a tooth pick or needle. Could be a tiny spec of anything acting like a check valve. Can be intermittent as heck.
Do not turn anything on with the end of the orifice off or you will find out how volatile 2 seconds of propane is. Cleared the dust out of my tree I can tell you for a fact.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
